WHICH PLENUM
Old Apr 5, 2005 | 01:00 AM
konnan99's Avatar
konnan99
Default WHICH PLENUM
How's everyone doin' ! I want to purchase a plenum but don't
know which one to buy. I'm stuck between C&L & ACCUFAB.
Some help please.
MAC cai
FORD RACING 70mm tb
BASSANI offroad x-pipe
FLOWMASTER catback
Old Apr 5, 2005 | 01:11 AM
Emann0007's Avatar
Emann0007
Default RE: WHICH PLENUM
same thing really C&L is a lil cheaper. Get a TB too!
Old Apr 5, 2005 | 01:15 AM
konnan99's Avatar
konnan99
C&L is a lot cheaper but ACCUFAB also looks better. I have a FORD RACING
70 mm tb, but I know 75mm tb is better. ACCUFAB or BBK?
Old Apr 5, 2005 | 01:30 AM
Emann0007's Avatar
Emann0007
I went 75mm BBk and C&L. Dyno testing was best with this combo, but I bet if you research you might find an xtra HP or maybe 2 from the full accufab setup. Only differenc I know of is that the Accufab units are polished, but you could always polish the others yourself.... I didn't bother polishing any of my stuff, and I have the trueflow inlet pipe as well, theres nothign shiny under t hood anyway..... Check out www.CNLperformance.com to get their dyno #'s....
Old Apr 5, 2005 | 01:33 AM
Emann0007's Avatar
Emann0007
just looked at the sit emyself, and now they offer the plenums polished as well for free $169 totalt and the inlet pipes polished for an xtra 25 bucks!
Old Apr 5, 2005 | 02:11 AM
kubball2005's Avatar
kubball2005
Definately C&L, costs less and gives you good gains with a 75mm TB.
[sm=closed.gif][sm=closed.gif][sm=closed.gif]
Old Apr 5, 2005 | 12:53 PM
Jglisson's Avatar
Jglisson
If you go to a different size TB will it require modification to a FIPK?
Old Apr 5, 2005 | 02:52 PM
kubball2005
No, it doesn't require any modification.
Old Apr 5, 2005 | 02:54 PM
DIVER8374's Avatar
DIVER8374
ORIGINAL: kubball2005
^^^^ Way to go [sm=exactly.gif][sm=goodidea.gif]
SilverGTV8's Avatar
SilverGTV8
I installed a C&L, and 75mm Accufab. The C&L is worth the money. A couple hours of sanding and polishing the inside will smooth out the rough texture and should pick you up the 1-2hp more that the Accufab plenum will get you.
