plenum
Old Mar 3, 2008 | 08:07 PM
smoke96's Avatar
smoke96
Default plenum
hey im buying a trick flow from Jbauer and dont know how to install it, does anyone have a site where i can get a diagram or instructions?
Old Mar 3, 2008 | 08:14 PM
brian1570's Avatar
brian1570
Blart
Default RE: plenum
u need a a flat head screw driver a nut driver a ratchet a 10mm and 8mm socket. after that its just nuts a bolts. u disconnect the throttle connection, disconnect the vacume connection, the iac, and all hoses/sensors. then u pull the 5 bolts at the bottom of the plenum.
Old Mar 3, 2008 | 08:22 PM
smoke96's Avatar
smoke96
Default RE: plenum
sounds good. is it really that easy to install the new one though??
Old Mar 3, 2008 | 08:40 PM
brian1570's Avatar
brian1570
Blart
Default RE: plenum
oh yeah dude, litterally nuts and bolts...if u can turn a screwdriver and crank a ratchet then u r qualified for this install...just dont forget to reconnect everything u disconnected.
Old Mar 3, 2008 | 09:02 PM
smoke96's Avatar
smoke96
Default RE: plenum
thanks dude. can i put any throttle body on this plenum?
Old Mar 3, 2008 | 09:29 PM
brian1570's Avatar
brian1570
Blart
Default RE: plenum
70-75mm. the 75 is what i have it works great.
Old Mar 3, 2008 | 09:31 PM
fruhdaddy's Avatar
fruhdaddy
Default RE: plenum
any throttle body up to 75mm but I dont think they make on bigger than that anyway...It should take you no longer than 15-20 min tops...
Old Mar 3, 2008 | 10:16 PM
smoke96's Avatar
smoke96
Default RE: plenum
yeh i was think of a 75. would i need any fuel uprades to run that set-up?
Old Mar 3, 2008 | 10:18 PM
smoke96's Avatar
smoke96
Default RE: plenum
what do you think my hp and whp will be with the mods below and the plenum, and steeda underdrive pulleys.
StangEatsRice's Avatar
StangEatsRice
Default RE: plenum
Nope throttle body and plenum is all you need. I've had mine off so many times i can take it off and reput it on in 20min.
