Ring and pinion pattern
Old Mar 9, 2008 | 10:10 PM
briansgonnawin's Avatar
briansgonnawin
Default Ring and pinion pattern
Hows this look? This is a used set. I think its pretty decent but its my first time so any input aprreciated, thanks. and yes i did a crummy job painting it
Old Mar 10, 2008 | 08:08 AM
Churchkey's Avatar
Churchkey
Default RE: Ring and pinion pattern
Looks good to me. Suggest looping a rag over the companion flange & pull on it to put some drag on it then turn the ring gear through in both directions. It needs to turn through smoothly. If you feel any kind of gear mesh it will be noisy. I like .008 for the lash between the ring & pinion.
EDIT: just noticed this is your first attempt. Be sure you have somepinion bearing preload, There should be some drag on the pinion when turning it. Same thingfor the carrier bearings.
Old Mar 10, 2008 | 04:37 PM
briansgonnawin
thanks for the input church.
And is there a big negetaive for having too much preload on the pinion? i couldnt find a inch/pound wrench so i did it by feel. its notciably tighter and this is on used bearings
Old Mar 10, 2008 | 05:14 PM
fyouceeku's Avatar
fyouceeku
http://www.precisiongear.com/pgtechpatterns.htm
Old Mar 10, 2008 | 06:33 PM
SINISTER's Avatar
SINISTER
Looks good to me as well. Check this link out, it is what I used when I installed my gears. Gives you the backlash specs and what not: http://www.superstallions.com/tech/d...ars/gears.html
Old Mar 10, 2008 | 09:55 PM
Churchkey's Avatar
Churchkey
ORIGINAL: briansgonnawin
IF the pinion bearings are to tight they will fail. IF you can turn the gears through by handusingthe ring gear only you should be good to go. IF you need to turn the pinion while trying to turn the ring gear to get them to rotate you have it too tight.
Trying to give my best description here. It is difficult to describe how something should feel.
Old Mar 11, 2008 | 12:09 AM
AmericanRicer87's Avatar
AmericanRicer87
looks good i beleive
Old Mar 11, 2008 | 12:21 AM
briansgonnawin
Hey those are great links, thanks. MAybe those links and/or info should be stickied? and i totally coulda have used that superstallions article few days ago!
And church, i can turn the ring gear by itself, not too diffcult
And i forgot to mention, compared to my old pinion, the pinion i put in is harder to spin(used bearing). old pinion i could turn it easily by my hand, now i need to exert a little force to turn it.
Old Mar 11, 2008 | 12:29 AM
AmericanRicer87
put a new pinion bearing in. you'll be tearing it down again. old bearings do not like to be re-torqued. they are cheap. You can rent an inch lbs torque wrench from autozone, the torque has to be close on the pinion bearing will wear out really fast. also don't forget to replace your wheel seals.
Old Mar 11, 2008 | 01:08 AM
briansgonnawin
i understand, thansk american ricer, I wanted to get my car running asap so i could go to one of the mustang cruisees this weekened. hmm maybe ill have to miss it, or i may just retorque it and run it so i can make it to the cruise. but is the wheel seals really necessary? i have seals and new bearings but dont wanna go though all that trouble yet
