Mystery Engine Problem...
Old Mar 18, 2008 | 11:35 AM
900RR Puzzle's Avatar
900RR Puzzle
Default RE: Mystery Engine Problem...
My problem was similar, except it would get worse with drive time, instead of better like yours. I replaced all 8 of my coils with new ones and it went away.
It almost sounds as though it could have an intake gasket bad, or something similar causing a vacuum leak. After the car heats up and everything expands, it runs fine. When it's cold and running rough, spray some water from a squirt bottle (or something like that) around where the intake bolts to the heads, and see if that makes it run smoother for a couple seconds. Don't soak it with a hose, you dont need to flood it with water.
Just a thought.
Brute03's Avatar
Brute03
i have a similar problem, mine bucks real bad under 1500 at low speeds and the power and economy absolutely suck....but the crappy shops around here can't figure it out [:@]
Old Mar 18, 2008 | 11:41 AM
Brute03's Avatar
Brute03
ORIGINAL: 900RR Puzzle
Just a thought.
ummm... you can't use water to find a vac leak, you need something that's combustible
Old Mar 18, 2008 | 12:19 PM
900RR Puzzle
Oops, your right.
I've used throttle body cleaner or WD40. I was thinking of the old water on the header pipe, to find a missfire.
Sorry.
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
