idling problems....
Old Mar 27, 2008 | 01:27 AM
racer02GTstang's Avatar
racer02GTstang
Default idling problems....
hey, ive been having problems with my car idling.... it idles fine when your not moving... but when your coasting in neutral or with the clutch in.... it idles at around 2000 rpms... what could cause all this???
Old Mar 27, 2008 | 10:35 PM
racer02GTstang
Default RE: idling problems....
bump
Old Mar 28, 2008 | 01:29 AM
STANG0446's Avatar
STANG0446
there are about 1001 posts on this problem, this usually happens after an intake and tb swap. I have change both my iac valve and my tpswith no luckand from what i hear this is just how these 2v's are set up you might be better off learning to live with it.
Old Mar 28, 2008 | 06:56 AM
Wishbone's Avatar
Wishbone
Mine idled at 1900 after tb and C&L intake. Lucky for me my Diablo Predator let me override the idle so I set it where I want it.
Old Mar 28, 2008 | 08:31 PM
racer02GTstang
ORIGINAL: STANG0446
it shouldnt be doing this though, its never done this in the past. and i had a intake, throttle body, and plenum. hell, it didnt do it when i had the supercharger on it. im not talking about the car dieing from the iac valve sticking. i have a P-51 intake manifold with an egr delete with a 75mm accufab TB. im wondering if it could be something due to the egr delete.
ive yet to see these 1001 posts on this problem. im on here all the time and most the time i only see posts due to a sticking iac or the idle is high in general after a swap of throttle body or plenum.
Old Mar 28, 2008 | 08:33 PM
racer02GTstang
ORIGINAL: Wishbone
did you adjust the idle on the throttle body??? ive never seen a programmer adjust idle on a car with a throttle cable??
Old Mar 28, 2008 | 09:03 PM
FixFalcon's Avatar
FixFalcon
ORIGINAL: racer02GTstang
ORIGINAL: Wishbone
The Diablo tuner is a very handy thing to have. You can adjust your idle speed, fuel mixture, gear ratio, tire size; hell you can even turn off your CEL.
Old Mar 28, 2008 | 11:43 PM
STANG0446's Avatar
STANG0446
search for idle problems and see how many threads you get! also just by looking on the first page i found this thread that might help you i have done it with gasket material and it worked for me. gl https://mustangforums.com/m_539808/tm.htm
Old Mar 29, 2008 | 12:08 AM
BADSEED's Avatar
BADSEED
clean your air filter and IAC and usually in the rain mine does it cause of the S281E hood im guessing everything gets wet and screws up
Old Mar 29, 2008 | 12:50 AM
racer02GTstang
ORIGINAL: STANG0446
i will try it in the morning... wondering if that will fix the problem. someone said it helped for their hanging idle. i thought the only thing the restrictor did was just make the rpms drop faster and that was it?
