Engine Problems
Old Apr 20, 2005 | 12:08 AM
01roushnj's Avatar
01roushnj
Default Engine Problems
Ok now I have faced RPM problems before and it usually just took a good cleaning of the MAF, TB, and IAC but this time its different. First, the car wouldn't stay idle for more than 5 sec before dying on me. I finally got it to start and tried reving the engine so see if the RPMs would stay up. When i pressed the gas pedal all the way down it stayed at 750RPMs which is incredibly low. I then noticed there was black smoke comming out of the exhaust. I popped the hood and unplugged the MAF sensor just to try it out. The result was rough idling between 500-1500 RPMs. In other words the car is undrivable. Anyone have any clue whats the prob??? Im guessing i need a new IAC valve and MAF sensor. Your comments are greatly appreciated.
Old Apr 20, 2005 | 12:52 AM
The02GT's Avatar
The02GT
Default RE: Engine Problems
uhhh, sounds like timing is WAY WAY off for some reason, did you just have it worked on somewhere?? What yr is it, did you cross plug wires??
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
HIS S-197
Aug 10, 2015 05:47 PM
Pain.
Aug 7, 2015 10:48 PM
