COP's
Old May 1, 2008 | 12:01 PM
04GTMustangRob's Avatar
04GTMustangRob
Default COP's
Alright, I am just trying to rule things out when it comes to my car not running right. So from some suggestions of some i did a resistance test on my COP's. my haynes book says that the primary resistance should be .5 ohms and the secondary resistance should be 5.5K ohms.
I used my ohm meter and got the following #'s on my COP's:
1P - .8
1S - 5.5K
2P - .7
2S - 5.48K
3P - .7
3S - 5.49K
4P - .8
4S - 5.48K
5P - .8
5S - 5.59K
6P - .8
6S - 5.43K
7P - .8
7S - 5.44K
8P - .8
8S - 5.45
so what do i gather from this? [/align]
Old May 1, 2008 | 01:43 PM
ackuric's Avatar
ackuric
Default RE: COP's
how did you check/test the cops? Seems your primary resistance is high, I can't say what problem that would cause though
Old May 1, 2008 | 02:17 PM
04GTMustangRob
Default RE: COP's
i used a volt/ohm meter
i am trying to diagnose this
https://mustangforums.com/m_4996633/tm.htm
Old May 1, 2008 | 02:18 PM
Sxynerd's Avatar
Sxynerd
Default RE: COP's
More resistance = less power getting to your plugs which = misfires = bad idle = poor combustion = bad mpg =.... Get it?
Your chilton says what the acceptible K omh resistance for secondary and for the primary. If they are within reason of each other and there's not any huge difference between any of them then your fine.
Old May 1, 2008 | 03:51 PM
04GTMustangRob
Default RE: COP's
ORIGINAL: sxynerd
thanks for the lesson (and no sarcasm there).the haynes book says .5 on the primary is acceptable. does this mean that the .8 is okay or no?
Old May 1, 2008 | 05:48 PM
LynnBob Mustang's Avatar
LynnBob Mustang
Default RE: COP's
Double check your book, I think it says if it is anything but the specs it is bad and needs to be replaced. There was no +- of the spec.
Lynn
Granatelli Sales
Mar 25, 2016 08:01 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
Webster454
Sep 5, 2015 11:06 AM
Calizic
Aug 28, 2015 01:46 PM
