Which plenum should I go with?
I need to start getting some stuff for the stang. I only have a CAI right now
I dont want to put gears in cause I dont want to sacrafice mileage.
ShouldI go with a aftermarket plenum?
Also which UD pullies should I get? The steedas are alil pricey.
ORIGINAL: hot wheels
do not buy an accufab tb/p, waste of phuking money. nothingbut problems. anything but that
i just replaced the accufab with the stock tb/p and everything is perfect now, the way it should be. no idle hang, and no drop in rpm's or dieing.
ORIGINAL: Cassies01GT
If they are nothing but problems why are you still sporting them?
THere all the same. I have the C&L and MAC 75mm and It made better gains with the s/c aplication than it did n/a. Some of your cheaper t/b-plen have a hard time mettering air at idle so you can get idle hang and high idle. Which can only be taken out by a tunner (decay rate). Thats the problem I had while N/A but after I put on the s/c i didn't have much of an issue.
Gary Ugarek
Aug 26, 2015 08:41 AM
