UPDATE ON NO START!!!!!!!!!!!!!!!!!!!!!
ok well i have no spark at any of the coils all of a sudden...anyone run into this and find out a problem i can check first before i go thru 15pages of a flow chart? and there is no fuse to check i looked.
RE: No Spark
Did you ground the spark plug to metal while watching it? Test light on an open connector won't work. It has to be pluged in, spark plug tighten in the hole for you to see a light. Stick a needle in the wire and attach the test light to that.
RE: No Spark
ok well my coils are producing spark...just replaced my spark plugs with NGK's and welll still no start.... but wait
i unplugged all the injectors so i can crank it and clean out the cylinders of fuel... and it fired up for the lil fuel it had in it....so i was like SWEEET it will work....then i plugged the injectors back in....NOTHING....unplugged agian...fired up as soon as i cranked it but died since the injectors were unplugged....plugged back in...and NOTHING....WTF.... my injectors stuck the **** open or something?
