subframe install?
Old Jun 3, 2008 | 05:20 PM
MustangMan00's Avatar
MustangMan00
Default subframe install?
hey guys how much roughly,do full length subframes cost to install/weld in a 2000 GT coupe
-Pat
Old Jun 3, 2008 | 05:26 PM
02 Ninja's Avatar
02 Ninja
Default RE: subframe install?
Full lenght sub frames cost about $100. You can install them yourself if you know how to weld. A lift would be helpful, but if you have jack stands, you should be able to do it.
Old Jun 3, 2008 | 05:33 PM
black35th's Avatar
black35th
The suspension needs to be fully loaded when they are welded on so you will need a place that has a drive on lift. Shouldnt cost any more than $75. If you have it on jackstands you run the risk of your body being tweaked and then welding it that way.
Old Jun 3, 2008 | 05:36 PM
MustangMan00
ya im def takin it to a shop so roughly an hr of labor?
-Pat
Old Jun 3, 2008 | 05:43 PM
black35th's Avatar
black35th
Yup probably about an hour, like I said though man just make sure whoever you take it to has a roll-on lift.
Old Jun 3, 2008 | 06:00 PM
MustangMan00
ya its a mustang specific shop that pretty much every stang aroudn here goes to im sure itll be done right
thanks a lot for the responses
-Pat
Old Jun 3, 2008 | 08:52 PM
jrherald420's Avatar
jrherald420
75 for install around here
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
Sep 8, 2015 11:50 AM
