tps
Old Jun 17, 2008 | 08:27 PM
armyflip123's Avatar
armyflip123
Default tps
i installed a plemun and 75mm throttle body. when i started up the engine it stayed at 2,000 rpm then went to 3500 rpm.. what could cause that problem. is there ne way to solve it. could it be the tps? or would there be something wrong with the instlation.
Old Jun 17, 2008 | 08:29 PM
02 Ninja's Avatar
02 Ninja
Default RE: tps
Could be the install. Double check yourself
Old Jun 17, 2008 | 08:35 PM
steve0914's Avatar
steve0914
Default RE: tps
can't you manually set the idle? just turn the screw
Old Jun 17, 2008 | 09:22 PM
jwog666's Avatar
jwog666
Default RE: tps
vacuum leak
Old Jun 18, 2008 | 03:36 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
Default RE: tps
Did you disconnect the battery for 5-7 minutes to reset the KAM? The Keep Alive Memory is where learned values such as idle air and short an long term fuel trims are storedany time you mess with intake or fuel system components you should reset the KAM...
Old Jun 18, 2008 | 10:23 AM
armyflip123
Default RE: tps
ya when i first installed it i disconnected the battery.
ShaneB26154
35
Mar 4, 2021 04:05 AM
mirandaandjimmy
Nov 16, 2015 08:51 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
bmorrisj
May 27, 2004 06:18 PM
