engine swap
Old Jun 24, 2008 | 09:50 AM
w8less's Avatar
w8less
Default RE: engine swap
ORIGINAL: 99BlackPonyGT
well jasper im probably going to be looking at a 4v 5.4 from a navigator....but what about this? i have this posted on a local forum and one guy said this
you can run a roller cam in the older engine's. a friend on mine has a 69 block 351 and he running a soild roller in it! just takes different lifters. you need the lifters with the tie bars in them. most companys make them
oh and the links you posted, only made it through part of the first one so far, but its a lot of good info....does the same stuff still apply to swapping it to my car? so far the only thing im looking at is for the 351
k member
headers
motor mounts
stiffer springs (maybe)
t5 tranny
gauge cluster out of a 94-98 (mechanical speedo)
ecu out of a HO foxbody
that is true. you need the tir bar lifters and roller is the way to go. your stock springs should be fine. your motor is heavier than a 5.0 and a lot of guys usually dont change there stock springs.
honestly the t5 wont hold a 351. a t5 will barely hold a stock 5.0
looks like your have everything else figured out.
you already have the hood
Old Jun 24, 2008 | 09:52 AM
w8less's Avatar
w8less
my buddy just told me he can get me a termie longblock for 2 grand...so im going to start saving...thats way cheaper than building anything
yea but then add in the cost of some termie heads. thats another 1,000. i know i bought some. then the intake and everything. stuff adds up.
if i were you i would look for a teskid block, buy a stroker, and go from there
Old Jun 24, 2008 | 10:08 AM
amoosenamedhank's Avatar
amoosenamedhank
This if for swapping a 302 for a 351W but it's got some good info in it.
http://www.sn95forums.com/Tech/302_t...Swap/index.htm
sn ninety five forums . com
Old Jun 24, 2008 | 10:11 AM
redstanger's Avatar
redstanger
5.4L DOHC navi engine. 98-00 . Higher flowing heads than a 03 04 cobras. Forged crank factory. Just need rods and pistons.
Go buy ford GT cams($499) and it will be one hell of a engine.
Thats what i wanted to do.
Old Jun 24, 2008 | 11:05 AM
amoosenamedhank
ORIGINAL: redstanger
Don't forget the $2000 custom sheet metal intake manifold.
Old Jun 24, 2008 | 11:06 AM
w8less's Avatar
w8less
i want to try the fr500 cams with my set up but i cant erv the motor high enough to take advantage of it
Old Jun 24, 2008 | 11:07 AM
w8less's Avatar
w8less
ORIGINAL: amoosenamedhank
i thought sullivan made a intake
Old Jun 24, 2008 | 11:12 AM
amoosenamedhank
ORIGINAL: Jasperstang308
Probably do but it's not going to be cheap either. Plus where are you getting Ford GT cams for $499? Any normal set of cobra cams is at least $1k.
Old Jun 24, 2008 | 11:54 PM
w8less's Avatar
w8less
what kinda of cobra cams are you talking about?
i know the fr500 cams are more. i found tge ford gt cams a while back for 600
Old Jun 25, 2008 | 12:18 PM
mcgilvrey007's Avatar
mcgilvrey007
modular mustang racing has an intake manifold for the 5.4 navigator, its $700
heres the link http://www.modularmustangracing.com/ its under the dohc stuff about halfway down
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
97SN95GT
Sep 13, 2015 09:45 PM
mdj89
Sep 6, 2015 11:08 PM
zachary1988
Sep 4, 2015 03:04 PM
