BIG PROBLEM! need help plz
Old Jun 21, 2008 | 08:12 PM
Davojan59's Avatar
Davojan59
Default BIG PROBLEM! need help plz
hey guys i took out my car today for the first time this week and while acclerating (in boost and not) it was hesitating, backfiring, and totally running like poop. I pulled over into a parking lot and popped the hood but couldn't really see anything wrong, all the injectors and cop's were on there tight. I decided to take it easy and go home and while i was on the last straightaway on which my house sits it kinda goosed it for a couple seconds but not too much and it did it again but this time i smelled something burning. The smell quickly dissipated but i dunno what it was. I dont think it was the clutch...either way the backfire/misfire was pretty bad. I was thinking maybe i need new spark plugs and/or COPs..? Anyone know how to test the COPs?? Well thanks in advance for any help provided.
Dave
Old Jun 21, 2008 | 08:33 PM
jrherald420's Avatar
jrherald420
Default RE: BIG PROBLEM! need help plz
thats not good. did you have a safe tune??
Old Jun 21, 2008 | 08:40 PM
oxfordgt's Avatar
oxfordgt
Still got cats?
Old Jun 21, 2008 | 08:50 PM
Davojan59's Avatar
Davojan59
my tune is pretty safe and its been the same since the first time i got it tuned (around 11.5 afr). No i dont have any cats and i did think about it too. I have an o/r x pipe
Old Jun 21, 2008 | 09:56 PM
iufan4lifeul's Avatar
iufan4lifeul
Try changing the plugs. I got a tank of bad gas where mine was missing all of the time, flushed the tank out and replaced the plugs and it ran good as new. And for $10-15 it wouldn't hurt to try the plugs.
Old Jun 22, 2008 | 10:06 AM
Davojan59's Avatar
Davojan59
oh ok i'll try to change the plugs. I have tr6s, does anyone know where i should gap them? Can i just look at the gapping on the old ones and go from there? Also is there a way to test COPs?? Thanks
Old Jun 22, 2008 | 12:33 PM
Davojan59's Avatar
Davojan59
ok i just pulled out one of the plugs and it had a lot of what looked like oil on the threads but when i smelled it and touched it (very thin) i thought it was some sort of anti seize or something. The tip of the spark plug is very dry and somewhat has a bit of whitish discoloration. Tested the COP with an ohmmeter and it tested good. Does anyone know if the part number for the tr6 is 4177??
Old Jun 22, 2008 | 12:50 PM
defconfire's Avatar
defconfire
white discoloration on the plugs is usually a sign of it beng too hot which usually comes from running lean (at least on an n/a car) I dont know if F/I changes anything?
Old Jun 22, 2008 | 12:59 PM
Davojan59's Avatar
Davojan59
oh ok well im not sure then...its only slightly whitish but who knows..So should i take it to the dyno shop and see what my afr is at? Another thing is that whereever i go trying to find TR6 plugs for this car they say that it wouldnt fit. Only tr55 would, even though i pulled one out just now. I called autozone and they have tr6 plugs but their computer says it wouldn't work for my car. What other plugs is everyone using with f/i??
Old Jun 22, 2008 | 02:33 PM
Davojan59's Avatar
Davojan59
bump
