cams
Old Jul 4, 2008 | 02:34 PM
Jordan123's Avatar
Jordan123
Default cams
im going to buy these cams from americanmuscle
do i need anything else
http://www.americanmuscle.com/mustan...s-xe262ah.html
there stage 1 do i have to have anything esle with them or can i just swap the cams?
and what do you think my power gain will be?
Old Jul 4, 2008 | 03:33 PM
945LSTANG's Avatar
945LSTANG
Default RE: cams
upgrade the stock valve springs.
boduke0220's Avatar
boduke0220
Default RE: cams
i think you'll need a tune but im not sure.
probably 15-20 hp and same on TQ
Old Jul 4, 2008 | 05:02 PM
jRock617's Avatar
jRock617
Default RE: cams
not to highjack this thread, but could somebody explain why one would opt for stage 1 cams when stage 2 cams are the same price? i know with stage 2 cams u need to upgrade the valve springs, but wouldn't they yield more power?
Old Jul 4, 2008 | 05:09 PM
mustangmancp's Avatar
mustangmancp
Default RE: cams
no they don't necessarily yeild more power...just a greater potential if you upgrade to a S/C and other things.
like i would only go for stage 1 now cuz i don't plan on S/C til out of college...cuz im only 16 and a S/C isn't rle needed haha.
and to the OP you would just need a tune for the stage 1 cams.
Old Jul 4, 2008 | 05:32 PM
rob.d's Avatar
rob.d
Default RE: cams
ORIGINAL: mustangmancp
Stage 1 cams are usually designed as a street style cam. ie more usable power were you need it. As you move up in stages then the design of the cam change for the drivers needs. ie strip car power is more in the upper rpm range, that you would not normally hit while driving on the street. Stage 2 cam would usually be more sluggish off the line because the usable power is in the upper RPM range so getting gears help this stylecam. Most people think the bigger the cam the better and thats not always the truth. You have to look at the whole setup (parts working together). And to say that a stage 2 cam is good for a super charger is just not true. The VE of that cam would make it a bad choice. ie too much overlap= wasted boost out the pipes. Do not pick a N/A cam for a supercharger. It will sound good, but wont perform like it should. To the OP learn to read a cam card and understand how VE play a role in howyour car will perform. And then decide if thats what your goals are for your car.
Old Jul 4, 2008 | 06:01 PM
steve0914's Avatar
steve0914
Default RE: cams
what other mods do you have? cams can give you 20 hp with a good tune
Old Jul 4, 2008 | 06:12 PM
mustangmancp
Default RE: cams
ORIGINAL: steve0914
+1 Didn't know tht they would give so much power...thts why i want sum SOOO bad!
Old Jul 4, 2008 | 10:44 PM
Jordan123's Avatar
Jordan123
Default RE: cams
i have pluemn, off road x pipe, aceel coils, cold air intake, underdrive pulleys and motive 4.30s and ill have headers and 75 mm t/b when i install stage 1 cams
Old Jul 6, 2008 | 01:56 AM
04BlueGT's Avatar
04BlueGT
Default RE: cams
With those cams, you can retain the stock valve springs and tune. However, since you're in there already, the springs would be a good idea. As for the tune, MM&FF says that you can get away with the stock tune, but you'll get the most from those cams with a tune.
