O2 Sensor Replacement Which Length?
Ok so kinda got some good news back from the Ford house. They told me that Bank 1 rear O2 sensor is faulty. I called AutoZone to see how much it cost, but they told me there were two different lengths. One is a 10 1/2" and one is a 18 1/2". Again, this is Bank 1 and Rear O2 on my 2004 GT. Thanks Guys!
DON'T GET A SENSOR FROM AUTOZONE, it won't work right!! one of the oxygen sensors went bad on my car recently (i think bank 1 sensor 2, same as u) and when i pulled the old one off...wouldn't u know it, it was a cheapy aftermarket sensor.
go to http://www.partscheap.com/ and give them a call. they'll hook u up with an OEM oxygen sensor for cheaper than anywhere else. that's who i went through to get mine and i have no complaints
+1 on NOT going to AutoZone, at least go to NAPA or the site he listed above.
I do believe that your gonna need a 10 1/2 though because the 18 1/2 should be for the front.
ORIGINAL: bb816331
Which brand does Napa sell? Oreilly's sells the Bosche one, is that one any good?
ORIGINAL: bb816331
EDIT: Napa's website says "OEM STYLE BSH 15716" which is the Bosch. If that's the case then Oreilly's has 'em cheaper...?
ORIGINAL: black35th
IDK man, I cant help you on brands, I've never had this problem. I would listen to art02gt and check with the stealership on the prices for Motorcraft.
Hmm...well i try going to Motorcrafts website to find the oem part number. It shows two different ones for downstream, and one for upstream. Which one is it??? Here's the part numbers:
RR - DOWNSTREAM - LH - XR3F-9G444AA
FRT - UPSTREAM - XC2F-9F472AA
RR - DOWNSTREAM - RH - 1R3A-9G444AB
Any idea of what these cost at the Ford house (other than an arm and a leg...?)
