Need to clear service engine light
Old Jul 15, 2008 | 05:35 PM
03GT/TRPLBLK's Avatar
03GT/TRPLBLK
Default Need to clear service engine light
My service engine soon light came on and i need to know how to clear it. I have the diablo predator with a custom tune. I think if you disconnect the neg battery terminal it will clear it but will that mess up my tune at all?? Any info would be greatly appreciated. Thanks
-Rick
Old Jul 15, 2008 | 05:50 PM
jwog666's Avatar
jwog666
Default RE: Need to clear service engine light
you should find out what the code is and why it came on first. the predator should be able to clear the code for you, its in the instructions. disconnecting the battery may clear the code and it wont mess up your tune. but using the predator will clear the codes without resetting your fuel trims
Old Jul 15, 2008 | 06:10 PM
enrobriaffej's Avatar
enrobriaffej
+1. that worked for me. and i have an 03 gt
Old Jul 15, 2008 | 08:36 PM
blownstangboosti's Avatar
blownstangboosti
you could do either or.
Old Jul 15, 2008 | 08:42 PM
Novanutcase's Avatar
Novanutcase
Before anything unhook the battery for around 45 minutes to reset the computer. When you hook the battery back up wait for a minute. If your "Service Engine Soon" light goes back on then check it for codes.
John
Old Jul 15, 2008 | 08:50 PM
black35th's Avatar
black35th
ORIGINAL: Novanutcase
John
Actually the ECU only keeps the KAM (Keep Alive Memory) for 7-10 minutes.
OP, everything that everyone has said is correct and you should really scan to see what the code is before you clear anything out.
Old Jul 15, 2008 | 09:37 PM
baino's Avatar
baino
+1- a benefit to the tuner is to read codes, why not use it
djbigskrilla
Sep 20, 2022 01:04 AM
J.casone400
Aug 28, 2015 09:33 PM
microgt
Aug 20, 2015 07:12 AM
kevans79@yahoo.com
Aug 18, 2015 08:16 AM
drumhedd2005
Aug 13, 2015 09:59 AM
