Power window problem
Old May 6, 2005 | 11:20 PM
justmejep3's Avatar
justmejep3
Default Power window problem
Passenger window wasn't going up or down from either switch.
SO FAR THIS IS WHAT I HAVE DISCOVERED.
1. It wasn't the motor
2. It wasn't the switch
So, I was at the local Autozone and a shade tree mechanic diagnosed that one of the wires (white one on passenger side) was not getting the current from the driver side, so he spliced from the blue one over to the white on on the passenger switch and the window works fine, no new motor or no new switch.
NOW.. the driver side switch have no control over the passenger side window. Supposely this white wire is not carrying whatever over to the passenger side is the reason he had to splice. I am a NEWBIE so can anyone give me more insight on how to aproach a solution, or even your thoughts on the current " jimmie rig" that's now in place, other than dealer re-wiring.
Thanx guys and gals that are out there!!
Old May 7, 2005 | 01:07 PM
01roushnj's Avatar
01roushnj
Default RE: Power window problem
check the fuse.......99% of the time its the fuse, it happened to me before.
Old May 8, 2005 | 12:06 AM
FoxGT's Avatar
FoxGT
My friend is having a similar problem with this 86 GT. The passenger side window will roll up, but not down.
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
movielover40
Aug 27, 2015 10:13 PM
HorsePower99
Aug 26, 2015 11:29 PM
