code pulled p1443? need help!
Old Jul 22, 2008 | 07:31 PM
stangman08's Avatar
stangman08
Default code pulled p1443? need help!
i hooked a scanner up to my 98 gt and this code was pulled..
p1443
Evaporative Emission System Control Valve
(low/no flow)
i looked the code up in the manual and it said..
Vacuum System - Purge Control Solenoid or Purge Control Valve fault
P1444
Purge Flow Sensor circuit Input Low
does anybody kno how to fix this or wat i need to replace? thax
Old Jul 22, 2008 | 07:47 PM
aponytoofast's Avatar
aponytoofast
Default RE: code pulled p1443? need help!
i'll try and help here. my '96 gt had the same problem. i replaced these two part numbers. e4zf-9c915-aa ( the part number on the replacement was e6zz-9c915-a) and f57e-14a606-aa (the part number on the replacement was f57z-14a606-ba) i cleared the code and it was good to go ever since.
i hope this helps.....
Old Jul 23, 2008 | 04:25 AM
stangman08's Avatar
stangman08
do u kno exactly wat kinda part u replaced? that would help me alot.?
Old Jul 23, 2008 | 07:33 AM
aponytoofast
one box said "valve assy" and the other just said "valve" as a discription. they were located on the right hand side of the motor and were inline with each other. pm me with your email and i'll send you pics of the old parts.
Old Oct 7, 2008 | 02:12 AM
findog78's Avatar
findog78
I got the same code on my Thunderbird and started by replacing the $15.00 F57Z-14A606-BA part first. The CE code still remains so I guess I will try the $60.00 E6ZZ-9C915-AA part now. Would you mind shooting me the pix of the parts you spoke of?
Thanks.
Old Oct 7, 2008 | 03:16 PM
findog78's Avatar
findog78
Found a pic of that solenoid...thanks anyway.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
