AC Problems!
Old Jul 26, 2008 | 01:41 PM
srahimi's Avatar
srahimi
Default AC Problems!
Hey guys I posted about my AC problem a few weeks back. When I turn it on it's not cold and my RPM's jump up and down. I lifted the hood the other day and turned the AC on full blast and I could hear a rhythmic hissing sound. Kinda sounded like hospital respirator that they use on people to help them breathe? Any ideas? I just wanna make sure that all I need is a recharge so I don't waste my time recharging the ACbut actually having a bigger problem on my hands that I don't know about. Thanks for your input guys!
Old Jul 26, 2008 | 02:37 PM
cjb7804's Avatar
cjb7804
Default RE: AC Problems!
The not cooling down sounds like it needs a recharge, but you need to look at the pressures and the sight glass. As for the RPM's jump up and down, if the are moving alot (around 400 on the low and 1100 on the high) mine was doing that and I ended up replacing the pressure cutoff switch on the filter/drier. Haven't had a problem since. I would recomend replacing the switch first, and then see if it takes care of both the problems. I picked the switch up at CarQuest for like $15-$20.
Old Jul 26, 2008 | 03:14 PM
srahimi's Avatar
srahimi
It's not quite jumping that much but it jumps about 200 to 300 in a constant rhythm. I can feel it while I'm cruising on the freeway so it's a pretty good spike. Thanks for the tip I'll check it out.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
