White Smoke Comming out
Old Jul 26, 2008 | 04:18 PM
boothay's Avatar
boothay
Default White Smoke Comming out
I have a 2000 stock Mustang GT and I changed out my spark plugs on friday moring along with my idler pulley. When I put everything back together and closed the hood getting ready to go to work , I tried to start the car and a puff of white smoke came from under the hood , and the tailpipes. smells like fuel. I think i made a mistake of spraying compressed gas down in the spark plug hole. is there any fix to my problem. I sprayed the compressed gas in there to get the sand and dirt out. Its also making a loud popping noise. Is there a possiblity that it could be a coil pack? I have the coil on plug and it doesnt want to stay alive when i get it started is there any way to test them?
Old Jul 26, 2008 | 04:20 PM
Swapped04's Avatar
Swapped04
Default RE: White Smoke Comming out
SES on?
Old Jul 26, 2008 | 04:23 PM
boothay's Avatar
boothay
nope when its cranked no ses light is on
Old Jul 26, 2008 | 04:25 PM
GrnStang96's Avatar
GrnStang96
Make sure all the spark plugs are tight if not they come lose and push the coil up it sound like a popping nosie
Old Jul 26, 2008 | 04:27 PM
Swapped04's Avatar
Swapped04
Then it is unlikely that you have a bad coil. Does the car run?
Old Jul 26, 2008 | 04:32 PM
boothay's Avatar
boothay
It runs for like a second. when I put my foot on the gas it dies down
Old Jul 26, 2008 | 04:34 PM
Swapped04's Avatar
Swapped04
And the SES light isnt on when the car is running?
Old Jul 26, 2008 | 04:40 PM
boothay's Avatar
boothay
nope
Old Jul 26, 2008 | 06:00 PM
jhell00's Avatar
jhell00
Possible Scammer
to test coils u can just start with any coil and unplug the wire going to it and if it runs worse then the coil works but if u unplug one and if it still runs the same then the coils prolly bad..
Old Jul 27, 2008 | 01:17 AM
kenv's Avatar
kenv
ORIGINAL: GrnStang96
Always use a torque wrench set between 11-13 ft. lbs
Diode Dynamics
28
May 26, 2022 12:02 PM
NTO_GUY
Dec 24, 2015 11:23 AM
overnight89
Aug 22, 2015 09:02 PM
WDScott
Aug 17, 2015 06:38 AM
