comp stage 3 cam
Old Aug 10, 2008 | 04:09 PM
GT_OBRA's Avatar
GT_OBRA
Default comp stage 3 cam
I have an 02' GT, full bolt on's, and was wondering how much HP gain i would get if i added a comp stage 3 cam and springs??
Old Aug 10, 2008 | 04:11 PM
35thAnni99GT's Avatar
35thAnni99GT
From: Where gunshots are more common than birds chirping
Default RE: comp stage 3 cam
I hope you have flycut pistons because you might have PTV issues with the duration on that cam.
Everything else not taken into equation, you sacrifice usable power under the curve for peak HP numbers. Its all about what you want to do with the car. If you have a road race/drag car that spends hardly any time below 4000 RPM then a big cam would be worthwhile, but if its a street car you want as much power under the curve as you can get.
Old Aug 10, 2008 | 04:37 PM
code3GT's Avatar
code3GT
Mustang Nazi
ORIGINAL: 35thAnni99GT
+1
Old Aug 10, 2008 | 05:31 PM
jefster411's Avatar
jefster411
what cam would you guys recommend for a daily driven mustang?
Old Aug 10, 2008 | 07:21 PM
johnr2001gt's Avatar
johnr2001gt
stage 2 hitech cams are awesome.
Old Aug 10, 2008 | 08:28 PM
Redfire UFO's Avatar
Redfire UFO
YOUR AN IDIOT, why would you get stage 3 cams on a mostly stock motor.... you are losing alot of low end power... i would recommend the stage 2 hi tech cams as well.... DO NOT BUY THE COMP CAMS, it will be a waist of money
Old Aug 10, 2008 | 08:45 PM
SeanAndKate's Avatar
SeanAndKate
hey red fire no need to be a dick he was asking because he didnt know so why not just say that the stage 3 are a waiste and he would be happy with the stage 2 hi tech. and leave the YOUR AN IDOIT out....
Old Aug 10, 2008 | 09:38 PM
livefast1's Avatar
livefast1
wow way to be a dick, if everybody knew everything there wouldnt be a reason for these forums. these forums are for people to ask for answers to questions they dont know, not for you to call someone an idiot. unless you were the original designer of the ford mustang im sure you dont know everything either so if you dont have anything informative to say why make an a$$ of yourself.
Old Aug 10, 2008 | 11:14 PM
GT_OBRA's Avatar
GT_OBRA
wow what a DICK man!! lol
Old Aug 10, 2008 | 11:19 PM
SeanAndKate
he probably just lost to a civic or something
