Question Seeking advice???
I own a 2000 mustang convertable..... I have put Magna flow, 70mm throttle body, pulley's,C&L plenum, fenderwell cold air, and headers.... what would i expect to see in the quarter? What about horse power? I think I should get a chip but there are so many manufacturs who is the best?
Thanks......
Ut544
Thanks......
Ut544
ORIGINAL: maddash
gt or v6? if you got a gt probably 250ish on the ground v6 and i wouldnt know if you got about $100 strap her
down to the dyno
down to the dyno
code3GT If it's a GT, there is no way you're putting down 250RWHP. Is your car an auto or stick? If it's a stick, you are probably in the 230RWHP range and an auto around 215-220RWHP. As far as the 1/4, low-mid 14's.
are u sure about that i though 99-04 "maual" dynoed at 230rwhp
to answer the first question get a diablo programmer...and quater mile times if u launch and shift good i do see y u cant do a low 14 high 13..get gears next and u will see even better #'s
ORIGINAL: 099gt
Sorry, you are correct about the weight. As far as the launch, convertible have more flex due to the lack of stiffness thanks to the top. Part of the weight is the added bracing to make up for the top, but it can't completely correct it.
