Turbo Cams?
Old Aug 27, 2008 | 07:34 AM
spetsnaz103's Avatar
spetsnaz103
Default Turbo Cams?
can anyone help me decide what cam to go with my twin turbo 4.6, i know its not the same for everyone but for me i will be making close to 500 horsepower. my shift goal is 6k i dont need to rev high. my problem is choosing a cam that will be ok with running a tt setup on low boost. can u run a supercharged cam with a turbo engine? if so why not this one. ive also been looking at custom cams and comp cams for a turbo application but i dont know what to choose.
http://www.cranecams.com/?show=brows...tType=camshaft
Old Aug 27, 2008 | 07:50 AM
spetsnaz103
http://www.lethalperformance.com/pag...-specific.html
Old Aug 27, 2008 | 10:58 AM
35thAnni99GT's Avatar
35thAnni99GT
From: Where gunshots are more common than birds chirping
See if they'll grind you a cam for the same price you can buy a preground one. I don't know what the specs are going to be on that one, but I think it's probably a pretty safe guess it's around .550 lift 23x/23x 114+ LSA.
Old Aug 27, 2008 | 11:41 AM
10inch Terror's Avatar
10inch Terror
I have a very popular 2V turbo grind. You don't need anything very agressive with a turbo. Mine will give you great power gains (have produced over 800hp) but will support the lower rpm power ranges and not scarifice low RPM power.
Old Aug 27, 2008 | 12:57 PM
amoosenamedhank's Avatar
amoosenamedhank
Don't run a s/c cam in a turbo set up. Most the time the supercharger cams have too much overlap for a turbo set up.
Old Aug 27, 2008 | 04:41 PM
spetsnaz103
love what u have i will be ordering from you. btw do i need new cam gears?
Old Aug 27, 2008 | 08:14 PM
10inch Terror
Only if you have a windsor motor with pressed-on gears.
Old Aug 27, 2008 | 09:37 PM
spetsnaz103
i have a romeo what about value springs i need to get new ones right.
Old Aug 27, 2008 | 11:28 PM
myslow2002gt's Avatar
myslow2002gt
Absolutely, and make sure you purchase either the Comp Hi-Load or Nextek valve springs, so you have sufficient spring load. The cheap Comp springs won't cut it with a turbo.
Old Aug 28, 2008 | 12:03 PM
10inch Terror
Yes..exactly what he just said....
GimpyHSHS
19
Dec 19, 2023 01:12 PM
TCStangerv6
Oct 11, 2015 05:57 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
