EGR pressure sensor affect anything?
Aug 28, 2008 | 11:19 PM
Hey guys I need to know if this affects the performance of my car any? the reason i ask is because it keeps melting the hose connected to it or the actual sensor ive had to repalce it twice. If it doesnt affect anything ill just leave it as is and not worry about it till i register my car again.
Aug 28, 2008 | 11:24 PM
Aug 29, 2008 | 05:38 PM
really? cuse if thats all it does then im fine with that
Aug 29, 2008 | 05:42 PM
that hose is most likely melting due to too much exhaust backpressure. usually a plugged converter or dented pipe.
Aug 31, 2008 | 05:35 PM
How would i fix a plugged converter? Im not seeing enough boost im getting like 3 lbs instad of the 6 or 7 i usually get.
Aug 31, 2008 | 06:01 PM
A plugged converter would make the boost go up, not down.
Aug 31, 2008 | 06:07 PM
Quote:
Originally Posted by
sxynerd
Yup, works just like constipation--clogged tail pipe = higher pressure...
Aug 31, 2008 | 06:08 PM
if you are running a turbo the high backpressure and lowered exhaust flow of a plugged cat will slow the turbo down and reduce boost.
Aug 31, 2008 | 06:11 PM
jwog666
What makes you think he has a turbo?
Aug 31, 2008 | 06:17 PM
jwog666
This is quite true, and also entirely irrelevant to this discussion...
