QUESTIONS!?!
Old Sep 25, 2008 | 02:28 AM
venom3469's Avatar
venom3469
Question QUESTIONS!?!
Ok i have 2500 dollers right now. I am looking to buy cams, intercooler, valve springs, lifters, and rockers. On cams i want something aggressive and most power range with most power. Any recommendations on what type and what kind i should get? Also you can see what i have done with the car already in my sig. So just wanting to know what all to get and the best kind you guys think is the best for me.
Old Sep 25, 2008 | 03:17 PM
jwarner0297's Avatar
jwarner0297
comp cams stage 2. after getting more knowledgeable on cams stage 3 don't benefit till after about 3700-4000 rmps with peak power not gained till about 7600 rpms. stage 2 is good cause its starts being beneficial at about 3000 and peaks hp at about 6500 rpm
Old Sep 25, 2008 | 04:13 PM
black35th's Avatar
black35th
CMS custom grind stage 2 blower cams and bump your PSI up to 8 and you should be looking at 400+HP with a good tune.
By the way, our cars have hydraulic lash adjusters (HLA's) not lifters.
Old Sep 25, 2008 | 06:58 PM
venom3469's Avatar
venom3469
ok that sounds good i appreciate it guys...but what about an intercooler?
Old Sep 25, 2008 | 07:45 PM
BOSTANG's Avatar
BOSTANG
Some custom grind cams. Maybe from mph. Some springs for the cams.I see that you have 31in splin. What about some subframe conn. and weld wheel with m/t?Look like you have a good set up going your way.
Old Sep 26, 2008 | 12:11 AM
vortech01vert's Avatar
vortech01vert
look at the cms stage 2.5 blower cams. talked to jim at cushmans and he said the stage 3's were for 700 plus cars pushing more than 20 psi. and he said the 2.5 would be an awesome choice for a strip and street vehicle
Old Sep 26, 2008 | 03:54 PM
venom3469's Avatar
venom3469
Yeah i also have traction bars on there now too. And ill look into the cams..
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
