de-stroking a 4.6
Old Sep 26, 2008 | 11:09 PM
J_Rod's Avatar
J_Rod
some of the benefits of destroking are hi revs, less recipricating mass, easier to add more boost, you have a more usable power band
Old Sep 26, 2008 | 11:14 PM
pcs's Avatar
pcs
very true, anyways why would you go with a kb if you want to de-stroke your engine for high rpm blasting? turbo or centri would be alot better for that application. good luck on your build though.
Old Sep 26, 2008 | 11:19 PM
J_Rod's Avatar
J_Rod
I have always been a fan of roots style blowers and i figure while destroking the motor i can spin it up to peak boost almost as quick as a turbo set up
Old Sep 26, 2008 | 11:28 PM
defconfire's Avatar
defconfire
You do realize with a roots or any positive displacement supercharger you always get full boost, it doesn't take revs at all..
Old Sep 27, 2008 | 12:42 AM
Aereon's Avatar
Aereon
Originally Posted by SVTeeshirt
^ lol i was talking about how im gonna design a v-8 that revs to 15kRPMS with a 150mm Turbo
in IRC ofc.
Lols, I'll believe it when I see it =P 150mm turbo heh.
Old Sep 27, 2008 | 01:44 AM
vortech01vert's Avatar
vortech01vert
yeah you cant spin the kb over 6k. well i mean you can but youll just mess something up and plus it wont make any power past that.
Old Sep 27, 2008 | 10:12 AM
J_Rod's Avatar
J_Rod
i never read on kb website when i ordered it that i couldnt rev it over 6500. They say it builds 1 psi higher at 6,000 and i am assuming an on it builds as it revs higher.
Old Sep 27, 2008 | 10:51 AM
Aereon's Avatar
Aereon
I would definitely call and ask before you make a costly assumption. They were built/designed to be used for a 4.6l 2v that doesn't see much rev's above 6-6.5k.
vortech01vert
http://kennebell.net/techinfo/ford-t...gtTechTips.pdf
first column last line
Old Sep 27, 2008 | 11:05 AM
J_Rod's Avatar
J_Rod
I would like to de stroke the engine but i dont want to destroy my KB. Would I still benefit from de stroking my engine but setting the rev limiter at 6k?
