2000 GT handling/suspension
Not sure if this should go in here or int he 4.6 general so i figured i would try here first.
I have a 2000 GT with less than 50k on the clock never seen a winter, and hardly sees rain. Periodically the car tends to pull/follow the road, and bounce around some. Other times it is straight as an arrow, and then some times its just all over the road. Does anyone elses do this? is it just the nature of the car? I have had it check out and front end aligned and they said its aligned and it doesnt pull. So idk if its something else w/ my car or if they all do that
Thanks
Thanks
hmm, i believe my front and rear tires are teh same size (width wise) could that make it follow the road more? i had it in the shop about two months ago to get new tie rod ends, power steering rack and a few other things, and had it in two times for an alignment, it goes straight as an arrow down a nice paved highway, but when you start hitting bumps or divets or more worn roads it tends to follow
im not exactly sure whats going on, its like it just randomly does it lol
Sounds like you're tramlining, only thing I can say is either get smaller/all season front tires or get used to it. The larger the tire/the more performance oriented (high perf tires vs all season tires) the more prone it is to finding and following ruts/grooves in the road. Also to check if your strut is going bad, press down on the front corners of your stang and check for bounce. If the spring goes back to its regular height without much bounce then move on to check the struts shaft for any leaks, if all comes back neg then you're going to need to look elsewhere.
heres my tire info
BF Goodrich G-Force T/A 245/45ZR 17 95W M+S
Edit: i mean im thinking on selling the car to get another mustang or something (02-04 GT 5spd, 99-01 cobra, ford ligtning) and if i go to sell it i just want everything to check out!
