Swap question
With the PI heads, cams, and intake on my 98 gt will that change my shift points alot higher? And will my redline still be at 6k? Right now my car is still making power up till about 5k w/ all my mods stock i shifted at 4500-4600 and i know that was right.
Is it just me? I've heard a lot about 4800 being the stock shift point between 2nd and 3rd gear--I have a 96 gt vert and if I floor it at launch (automatic tranny), second gear sticks until it almost reaches the redline--I have literally NO POWER between 4800 to 5900, so I'm waiting like 2 seconds for the damn gear to shift, and when third kicks in, it's a jolt of a boost forward. Is that the way it's supposed to be stock?!?! Please let me know! Damn confused...
Well im not to familiar w/ the auto's i dont like em. I have a 5 speed and I know my car stock didnt make any power at all past 4600. So try shifting it yourself. At around 4500 each time.
ORIGINAL: andy98gt
What do you mean shift myself? Thanks!
ORIGINAL: Gaspi101
It's an AUTOMATIC...how am I to shift myself? Remember that putting the tranny in 1 or 2 instead of Drive only limits the transmission shift, and when you put it on 1 it only PREVENTS a shift to second, and on 2 it similarly prevents shifting to 3rd--It does not shift manually--meaning, if I'm flooring it while on 1, even if I flip up to 2 at 4800 rpms, it will not shift until 5900 rpms. Just because the limitation is removed, it doesn't mean it would be manually shifted.
ORIGINAL: andy98gt
This was my problem. The car made peak power at low 5000s, but if I shifted there it would drop so low in RPM that I was outta the power band down low too.,
