Lifting Engine
Old Oct 15, 2008 | 04:15 PM
zero2005's Avatar
zero2005
Default Lifting Engine
So im doing a full K-member, A-arm and Coilover suspension install...
managed to get everything off and now im trying to lift engine. decided to just use my jack with a piece of cardboard and wood and jack it up using the oil pan.
so i started jacking it up and the passenger side is lifted off the k-member, but the drivers side motor mount seems to be supporting weight, like its unbalanced. cant move the driver side motor mount.
not sure if i should jack it up another 1/2 inch or so, or what? any ideas? its probably already about an inch and a half in the air.
Old Oct 15, 2008 | 05:09 PM
medrick's Avatar
medrick
when i lifted mine up for the headers i jacked it up until it was hitting the firewall for more clearance. go for it. it is probably just not perfectly balanced like you think.
Old Oct 15, 2008 | 05:31 PM
zero2005's Avatar
zero2005
yea i jacked it up as much as i can, there's a bracket on the top of the intake manifold thats hittin the firewall now. dont wanna bend it and its gettin dark out so im not gunna take it off.
i looked at the motor mounts, passenger side one is toast me thinks... the rubber or whatever it is, is cracked horribly. the driver side i have found that the bolt is dragging its threads across the k-member slot as i jack it up. its only got about a 1/4 maybe even an 1/8 of an inch to go until its full off though.
im thinkin of dropping the k-member without fully getting the motor "off" of it... and im thinkin that new motor mounts might be in order. will try and get pictures up...
mtgldr
Feb 3, 2024 09:00 PM
Nick Oliver
Oct 17, 2018 04:22 AM
musnicki
Sep 23, 2015 07:11 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Insidian
Carolina Regional Chapter
Sep 8, 2015 05:33 AM
