CHK ENGINE LIGHT/NO CODE
Old May 24, 2005 | 12:50 AM
sfi's Avatar
sfi
Default CHK ENGINE LIGHT/NO CODE
Has anyone had a chk engine light come on and when you go to chk the code there is no fault. I just put long tubes on w/ mils. Is it possible the mils are bad. How do you chk.
Im reading the code w/ a predator. The chk engine light come on about 30 min after I reset the fault.
Old May 25, 2005 | 11:55 PM
Jglisson's Avatar
Jglisson
Default RE: CHK ENGINE LIGHT/NO CODE
I doubt the Predator will pick up an enhanced code. This is more then likely the problem. You have generic and enhanced codes. Cheap OBDII scanners will pick up generics, but not enhanced.
Old May 26, 2005 | 01:35 AM
Guest
Guest
Posts: n/a
Perhaps it's your gas cap?
I know OBD2a/b Civics have the CEL turn on when the gas cap is missing/not tight enough. (don't ask me how I know this personally)
Old May 26, 2005 | 01:40 AM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
ORIGINAL: sfi
I've had that and it was just my CAI had loosened off a bit at one of the joints and was leaking air.
Old May 26, 2005 | 01:56 AM
sfi's Avatar
sfi
Thanks for the info. I got bad info. from someone on LT installs. They said I needed 4 mils. SO I have 4 mils on. I called predator and they stated to remove the front mills and that should solve the problem. What a waste of money. IM sure lesson learned.
If it doesn't go away, Ill chk the other possible issues you suggested. It happened right after the install, so I hope I didn't damage anything running mils up front.
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
zanemoseley
Sep 6, 2015 12:58 PM
zachary1988
Sep 4, 2015 03:04 PM
