quadrant
Old Oct 20, 2008 | 10:46 AM
jtfrog's Avatar
jtfrog
Default quadrant
Can someone explain the difference between single hook and double hook Quadrants?
Old Oct 20, 2008 | 12:53 PM
Young_Buck's Avatar
Young_Buck
one has "one' hook and the ladder has "2" hooks for better positioning of the cable.
Old Oct 20, 2008 | 03:01 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Yup, guess how many a "triple-hook" quadrant has?
They all requite that you use a firewall adjuster as well, triple hook (and some double hook units) quadrants will let you use the OEM cable instead of requiring an aftermarket adjustable cable. Aftermarket cables are very often compared to steaming piles of excrement, as compared to the stock cable.
Also, be aware that many single hook quadrants are designed to provide a quick-release by changing the contour of the quadrant. This will also increase the amount of pedal effort required.
I have the UPR triple hook quadrant, and their Extreme quick-click adjuster--highly recommended...
This is UPR's "speed release" quadrant.
Old Oct 20, 2008 | 05:01 PM
Young_Buck's Avatar
Young_Buck
I believe also the only triple hook quadrant is the UPR unit. The only reason for that is so they could copy steeda and get around there patent by adding a 3rd usless hook.
Kudos to them. I still bought the steeda.....sucks to be me......just go with upr.
Old Oct 20, 2008 | 05:11 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Could be, if so good for them--I got their 3-hook quadrant and the quick-click adjuster for $44, call them up and tell 'em that's what you want to pay--they will work with you...
Old Oct 20, 2008 | 06:03 PM
lizzyfan's Avatar
lizzyfan
Underboss
And they truly are shyte!!!
Old Oct 20, 2008 | 07:09 PM
02 Ninja's Avatar
02 Ninja
i bought this one http://www.latemodelrestoration.com/...0%201&comp=LRS, but i should have bought this one http://www.latemodelrestoration.com/...0%201&comp=LRS
Old Oct 21, 2008 | 07:44 AM
jtfrog's Avatar
jtfrog
I want to use the stock cable with no quik release so what would be the best?
Old Oct 21, 2008 | 08:26 AM
OzzDOA's Avatar
OzzDOA
I have the UPR quadrant and adjuster and am quite satisfied. The Steeda double hook is nice as well, but for the adjusters I would stick with UPR or Fiore.
Old Oct 21, 2008 | 08:29 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
My vote is for the UPR 3-hook and their quick-click firewall adjuster. Call them and ask for a deal...
