Left Blinker problem
Old Oct 21, 2008 | 06:45 PM
2003gtstang's Avatar
2003gtstang
Default Left Blinker problem
Recentally i went to turn on my left hand singal light ( blinker) and it was twice as fast as normal. Now it does it all the time. The right one is normal speed. What is this a bad fuse or soemthing?
Old Oct 21, 2008 | 06:58 PM
BraMas's Avatar
BraMas
Sounds like you a little low on blinker fluid. Good time to switch to synthetic.
Old Oct 21, 2008 | 07:18 PM
defconfire's Avatar
defconfire
You mean Halogen fluid, lol
I know on some cars if one light burns out the other does that. But you said your right signal still worked. Do both the front and rear turns signals work?
Old Oct 21, 2008 | 08:00 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
One of the left side lamps is blown...
However you may also want to check the blinker fluid.
You can get some here, it's sold out right now but that's the best price anywhere...
Old Oct 21, 2008 | 08:13 PM
Evenexchange's Avatar
Evenexchange
That means that one of your bulbs is about to go, that's all.
Old Oct 21, 2008 | 08:14 PM
2003gtstang
Where do i put the blinker fliud, also what is it?
Old Oct 21, 2008 | 08:18 PM
Evenexchange
The blinker fluid is a requirement for most of the "older" model cars.. but until recently basically all of the 2005+ cars have whats called "SPE" (self powered electric) designs where they no longer need this fluid. Our cars require them, and usually you should only have to change the fluid once (possibly twice) throughout the entire life of the car. The problem you are describing might require you to switch to fully synthetic fluid. There's a link to it above.
Old Oct 21, 2008 | 08:30 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
I think I saw a TSB describing a defect in some of the Mitsubishi sourced BFPs (Blinker Fluid Pumps), as safety equipment it should be covered even on older vehicles.
Old Oct 21, 2008 | 09:13 PM
blackstallion666's Avatar
blackstallion666
i just shake my head in disguist ...............
Old Oct 21, 2008 | 09:17 PM
Donnie's GTS's Avatar
Donnie's GTS
one bulb is burnt out.
