Please help me!! Re: Engine compression
Old Nov 2, 2008 | 09:47 AM
GT2ENVY's Avatar
GT2ENVY
Default Please help me!! Re: Engine compression
OK, i'll try to make it short, but explain it well. I have a 96 gt automatic that over the last year has gonr through a pi swap, comp cams stage 1, full exhaust (x-pipe no cats), 3.73 gears, full bolt-ons, rebuilt engine with 10 to 1 compression pistons. My point is that recently i ahd an issue with the car. I took it to the engine builder and he concluded that it was the pistons (the new motor has no more than 2000 miles). So he contacted the manufacturer to let them know that it was a defect with the pistons. The manufacturer told him it was his fault because the cars compression is too high and in order to help the car not destruct itself again, he needs to put at least two catalytic converters back in order to reduce the back pressure and to put a stall converter so it can help relieve the pistons. I'm not too mechanically inclined, but this all sounds like a bunch of you know what. I think he's lying of just doesnt know. I did see the pistons and 4 of them were cracked from the ring. I think he didn't install them right. It was under warranty so I am not paying anything, but I dont want this to happen again. I honestly think the problem is the fact that i have never tuned the car. No hand held or dyno tune at all. The car may be running lean which can lead to what happened. Could this be the problem or what can it be? PLease educate me. Thanks guys.
Old Nov 2, 2008 | 10:28 AM
NinetySix GT's Avatar
NinetySix GT
Were you using 93+ octane?
Old Nov 2, 2008 | 12:45 PM
GT2ENVY's Avatar
GT2ENVY
No. I'm here in CA so the the highest i can use is 91 octane
Old Nov 3, 2008 | 02:37 PM
GT2ENVY's Avatar
GT2ENVY
bump...
Old Nov 3, 2008 | 04:30 PM
Obsequious1's Avatar
Obsequious1
You have all that work done and no tune ? I suggest that when its all back together you have it tuned.
Nick Oliver
Oct 17, 2018 04:22 AM
bconboy
Sep 21, 2015 12:52 PM
uberstang1
Sep 20, 2015 06:42 PM
rksnow1
Sep 14, 2015 08:46 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
