MAF Question?
One way you can tell is by the MAF voltage output. It will peg and then go flat. I could tell mine had pegged by the way they were forced to tune the A/F ratio. They had it running rich mid-range so it wouldn't go lean at 6k rpm. The stock MAF is good to about 350 rwhp. To get my A/F ratio correct I had to get a MAFia and a new tune.
My first tune was on a Mustang Dyno. It's accurate (some say more accurate) but different than a Dynojet. It is generally thought that Mustang Dyno will come in with a lower rwhp than a Dynojet. My second tune (several months later) was on a Dynojet. The first pull before the re-tune was exactly the same as the Mustang Dyno.
I'm not a expert, but I think 36 lb injectors might be a bit small for 10 lbs of boost. I'm running 42 lb injectors. Before I bought the ProCharger I looked at a Saleen twin-screw. It came with 36 lb injectors. They said if I was going to change the pulley I would have to buy new injectors. That was one of the reasons I when with the ProCharger.
Whether its the MAF or the injectors, I think you should be getting more than 346 rwhp with 10 lbs of boost.
I'm running 42lbh injectors and a lightning 90mm maf with 10psi. I don't think I could've made 380/375 without them. If you look at some of the kits they sell on superchargersonline.com they recommend larger maf, http://www.superchargersonline.com/p...=PC-1FE212-SCI
Even on the 8psi kit, its has 42lbh injectors.
If I were you I'd upgrade and have it dyno tuned.
Injector Size
19 lb. 276 hp
24 lb. 349 hp
30 lb. 436 hp
36 lb. 553 hp
42 lb. 611 hp
55 lb. 800 hp
