MSD cops
Old Nov 20, 2008 | 04:39 PM
MaKaVeLi's Avatar
MaKaVeLi
Default MSD cops
what about the MSD coils ? are they worth 350 $?
Old Nov 20, 2008 | 05:44 PM
J_Rod's Avatar
J_Rod
i bought msd ignition coil packs for my 96. I would keep the stock ignition personally until one of your coils go bad. Jegs has an EZ kit which uncludes: MSD 8.5 wires, 2 coil packs, and 8 NGK plugs. That ran me $320.
With your mods you may notice some difference in performance, but most likely you may gain .5mpg... or your car will start easier.
Personally I wouldnt bother
Old Nov 20, 2008 | 07:35 PM
03BottleFedGT's Avatar
03BottleFedGT
when it comes to the coil packs it cheaper to get the msd ones than it is to go to a parts store and but new replacments (all 8). but i would wait till one goes bad before i spent the money
Old Nov 20, 2008 | 09:02 PM
02 Ninja's Avatar
02 Ninja
Stock COP's are just fine. Most will tell you that the only time you will benefit from aftermarket COP's are when you are running a high HP car
Old Nov 21, 2008 | 07:22 AM
MaKaVeLi's Avatar
MaKaVeLi
wil, i dont think that my current coils has been changed since it mades, some times my car would not start up immediately, and sometimes it shutt off suddenly ! however some says that the msd coils are better then stock 300% !!
Old Nov 22, 2008 | 09:40 AM
pcs's Avatar
pcs
the jegs kit will not work for your 02 stang, you stang doesnt use 2 coil packs or wires. you have 8 coils. i got them (msd) and notice no difference on how my stang runs or any change in the plug color and my coils have been in there since 99. if you coils are bad, then it wouldnt hurt, but i would just replace the one that is bad from another stang. a friend of my install the gms c.o.p.'s on his 07 gt and no difference either, he is running spray, cams,full exh, gears, and cai. its up to you though. with that $350 id get an intake plenum with 75mm tb to get better breathing from you cams.
Old Nov 22, 2008 | 04:31 PM
MaKaVeLi's Avatar
MaKaVeLi
i already had them
thanx alot man, so i thinks its just a waist of money :S
Old Nov 23, 2008 | 12:45 AM
Sxynerd's Avatar
Sxynerd
Not worth the powder to blow them to hell.
Old Nov 23, 2008 | 07:40 AM
96GT226410's Avatar
96GT226410
CSMG Moderator
Stock coils are pretty good pieces. Like said above, if one goes bad and you can't find a used set somewhere, then get them - just to make the engine bay look prettier.
Old Nov 23, 2008 | 10:45 AM
pcs's Avatar
pcs
Originally Posted by MaKaVeLi
i already had them
sorry, i didnt see that on your mods list.
Granatelli Sales
Mar 25, 2016 08:01 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
firehorse02
Nov 16, 2015 11:28 AM
mirandaandjimmy
Nov 16, 2015 08:51 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
