3k at 90mph
It would seem that you have 3.55:1 gears, assuming your tire size is stock.
Here's my "How fast can I go in each gear?" calculator, select the auto transmission from the drop down list and 3.55 as the gear ratio = 89.5 in high gear at 3k RPM...
Top speed in our cars is limited by horsepower, a 3650 with the 3.27:1 stock gears has a theoretical top speed of 225 mph or so. Thing is it would take 500+ rwHP to push it that fast (here's my "How much HP does it take to go how fast?" calculator).
Running n/a 145 to 160 is about as fast as you can get a new-edge rolling, depending mostly on overall gearing.
The 5-speed with 3.73s or 4.10s, and the auto with 3.55s (as you car seems to be), are the "sweet" combinations putting rpms at top speed right on or very close to the HP peak.
My car with the 3650 transmission and 3.73s would be turning a bit over 5k rpm at 160 in 5th, which is just a bit past the HP peaks at 4800. Fastest I've had it going was 138.3 per my GPS receiver.
i jus jacked my car up in the driveway and put a piece of tape on the well and fender wheel and a piece on the driveshaft and it spun 3 1/2 times so my guess is i have 3:55's which suck imo and im goin 4:10's!!!
