3650 problems
Old Nov 29, 2008 | 05:45 AM
DickH's Avatar
DickH
Default 3650 problems
OK, I picked up my car used and have been driving it for ~10k miles so far. the thing that has been bugging me is that it is hard to shift. There is a bit of a hesitation before going into gear, sometimes rejecting completely, sometimes grinding very badly. I am assuming bad syncros, could it be anything else? How much does a set of syncros cost and how much does it usually cost to have them replaced?
Old Nov 29, 2008 | 07:46 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
If you are certain the clutch is not dragging then it sounds as though the tranny has been pretty well thrashed. Synchro rings are one, and maybe the most likely, possibility--you won't really know until you open it up.
Cost depends on how much you can do and how much you have to pay someone else to do. If it's 100% DIY (including R&R of the tranny) then maybe as little as $250 to $400 for the parts. If it's 100% "pay someone else" then $2000 to $3500, maybe more depending on who does it.
Old Nov 29, 2008 | 08:49 AM
jmac72187's Avatar
jmac72187
corner carver
If you can pull the tranny then you can save a good amount. It would probably be about $1000-1500 if you can.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
