Differential cover replacement
Old Nov 29, 2008 | 09:09 AM
steve0914's Avatar
steve0914
Default Differential cover replacement
my differential cover is leaking because the retards bent it while installing my gears, how hard is it to replace and refill it? is it worth it to buy an upgraded one of the steeda or other brand or just buy an OEM?
Old Nov 29, 2008 | 09:24 AM
Timspony's Avatar
Timspony
SVT Section Moderator
....Really not hard! Just drain the pumpkin, clean the mounting area up real good, I button the cover up with silicone, add 2 quarts of fluid & friction mod...done!
Aftermarket cover making the draining & filling a lot easier...+looks good! ...you'll need about 3 quarts with aftermarket cover
Old Nov 29, 2008 | 11:02 AM
steve0914's Avatar
steve0914
is there a plug i can remove to refill it? i was told i can put a little sealer in there and then hammer it so it will pinch tight
jmac72187's Avatar
jmac72187
corner carver
I would do the aftermarket. It won't be as much of a bitch to change the fluid then.
Old Nov 29, 2008 | 01:12 PM
0440thgt's Avatar
0440thgt
Good luck holding down your cookies if you haven't smelled rear end oil!
That stuff smells like eggs that have been rotting for 5 years mixed with the fattest, smelliest chick that you can imagine.
Ehhhhhhhh. Maybe it's just me. haha
Old Nov 29, 2008 | 01:17 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Christ, it's not that bad. I have smelled worse things. Just do what Timspony suggested if you can afford an aftermarket cover. I just put a TrickFlow cover on mine. It has a support for the bearing caps as well as being able to change the fluid w/o removal.
http://store.summitracing.com/partde...5&autoview=sku
Old Nov 29, 2008 | 01:49 PM
Novanutcase's Avatar
Novanutcase
This is what the Trickflow cover will look like on your car:
John
Old Nov 29, 2008 | 04:01 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Yeah but you won't see it when the car is on the ground
Old Nov 29, 2008 | 05:45 PM
Jbauer's Avatar
Jbauer
whats the point of going aftermarket? crap, it's not like it does anything useful and your only going to change the dang fluid like once every 50k miles..and thats if your on the ball. I bet many people probably NEVER change the rear end fluid and drive it 200k or more miles just fine, and thats with the stock crap in it..most of us use redline and royal purple oil.
Old Nov 29, 2008 | 07:25 PM
steve0914's Avatar
steve0914
thats why i have to upgrade, saw that when i had my gears installed, it is warped and i had them bend it back pretty well, and used some gray liquid gasket on there, but i really need to replace it
