difference between 97 and 99 4.6 cobra engine?
Old Jun 3, 2005 | 05:50 PM
all4rks's Avatar
all4rks
Default difference between 97 and 99 4.6 cobra engine?
Is there any difference between a 97 and 99 cobra engine? Is one better than the other? I am buying one and they are both the same price.
Old Jun 3, 2005 | 07:14 PM
mustang_montana's Avatar
mustang_montana
Default RE: difference between 97 and 99 4.6 cobra engine?
well the 99 has 330 hp and the 97 has 300 i thought, and id go with the newer one regardless.
Old Jun 3, 2005 | 07:32 PM
Obselite's Avatar
Obselite
99 has better heads and more secure intake manifold.
and yes, it has about 30-40 extra hp over the 97.
i dont know where montana got 300 and 330 at, but you can expect about 195 from the 97 and 225 from the 99 ( on average ).
I also prefer the newer look as well...good luck!
Old Jun 3, 2005 | 07:42 PM
Quatrocky's Avatar
Quatrocky
97 has 305 hp, we dont really know what the 99's have since they were messed up. There suppose to have 320 hp. 97 didnt have IRS
Old Jun 3, 2005 | 07:44 PM
SilverGTV8's Avatar
SilverGTV8
The 99-00 Cobra had intake issues with the runners. As a fix ford replaced the intake and exhaust to meet the advertised HP and TQ numbers.
I would go with the 99 regardless..
Old Jun 3, 2005 | 07:57 PM
nanaki's Avatar
nanaki
Retired MF Moderator
ORIGINAL: Obselite
where'd you get 225 from? a 98 GT has 225 at the crank, not the cobra.
Old Jun 5, 2005 | 03:24 PM
DeViouS's Avatar
DeViouS
ORIGINAL: SilverGTV8
cobras werent made in 00.
anyway i would get a 99 b/c of the body style
Old Jun 5, 2005 | 03:42 PM
SilverGTV8's Avatar
SilverGTV8
Certainly were, they were called Cobra R's and not something everyone could purchase
Old Jun 5, 2005 | 08:28 PM
Acer2428's Avatar
Acer2428
Site Mod
Damn you, beat me to it!
Old Jun 6, 2005 | 02:59 AM
cobra mike's Avatar
cobra mike
96-98 cobra 305 hp 300#s of torque..4 valve heads with 8 ports per hear one for each intake valve, they used an i.m.r.c. plate (intake manifold runner controller) to boost low end torque...97-98 heads are call c heads, they are not as good for a n/a applicatoin, but they flow better for a turbo or supercharger setup.
99-02 cobra 320 hp 320#s of torque new head design called tumble port, one intake hole for both intake valves in cylender. 99s had intake problems that wher fixed on later modles, heads on these are better for n/a applications, but work well with supercharger, no i.m.r.c, less hassel.
both engins have the same bottom end. both have the same power potential, 96-98 uses a less complicated computer . the 96-98 do get better gas milage if that matters too you
