Are underdrive pullies worth it??
Old Jun 4, 2005 | 06:39 PM
jcdavis's Avatar
jcdavis
Default Are underdrive pullies worth it??
I am ready for my next bolt on and underdrive pullies come to mind. I have been told that they are not worth the risk of the constant draining of the battery. I want more power, but don't want to get stranded. Horsepower is no good if you can't get your car started.
Old Jun 4, 2005 | 06:52 PM
devinsteen's Avatar
devinsteen
Default RE: Are underdrive pullies worth it??
THey are worth it. I just got mine on and I feel some nice gains. I have 2 400 watt amps hooked up to my battery and it's still running fine. I turned on the AC, lights, and blasted my music and the car was perfect at idle. So don't worry about that...the battery will charge.
Old Jun 4, 2005 | 08:18 PM
jkm1987's Avatar
jkm1987
www.bbkperformance.com has some on sale for really cheap in their test products i just bought a set fol $105 and a throttle body for $150 go check it out
Old Jun 4, 2005 | 08:42 PM
Aongus's Avatar
Aongus
I wouldn't worry about the battery drain unless you are running some serious stereo equipment or have other electrical drains on the system that are out of the norm. Have you added rear end gears? You won't get any more power but you will definitly feel it in performance. It brings the mustang to a new level from a launch standpoint. 3:73's or 4:10's. THat is a whole other can-o-worms though.
Old Jun 4, 2005 | 09:54 PM
jcdavis's Avatar
jcdavis
What is the difference between a good set of UD pullies and a bad set. I have a 30 mile commute on I40 at 80 mph. I am a little weary about changing my gears and losing fuel mileage.
Old Jun 5, 2005 | 02:15 AM
the07sniper's Avatar
the07sniper
there is a difference between god and bad pullies. some pullies are considered pulyback pullys, which is why most people recomend steeda or march (steeda is better of the 2) look up on piggyback pullies and see why u should get steeda.
Old Jun 5, 2005 | 02:16 AM
jishead's Avatar
jishead
I am extremely happy with my Steeda UDP's. I've had them for like 9 months or 10,000 miles. I've driven them in harsh 2 hour daily commutes, long trips, stop and go, dyno runs, etc and had no hint of probs relating to alternator, steering or H20 pump. I highly recommend them. It's amazing how much faster the engine revs. I hit redline so fast. I can't imagine how fast it will be when I get my 4.10's installed!
Old Jun 6, 2005 | 12:00 AM
freeunit's Avatar
freeunit
how much do the steeda pullies cost and can you install them yourself with instructions?
Old Jun 6, 2005 | 12:14 AM
BicketyBam's Avatar
BicketyBam
Steeda's are $199 at mustangtuning.com. I installed mine myself, but I had help from some guys at work. You need a 3 bolt puller to remove the crank pulley. Other than that, it's not that bad.
Old Jun 6, 2005 | 05:41 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: the07sniper
Ya, get the ones that are 'single piece' design, not the piggy back style. The piggyback ones tend to cause balance issues if not properly installed or if they wear out. Even if properly done you may still have problems.
Personally, I wouldn't do UD pulleys because of the extreme heat here in AZ during the summer. Between the slightly lower coolant flow and the slightly lower charging capacity, I would probably end up stranded on the side of the road in 115 degree weather...that would stink.
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
treesloth
Sep 28, 2015 07:03 AM
ctgreddy
Sep 20, 2015 08:35 PM
GimpyHSHS
Sep 18, 2015 12:27 PM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
