having a problem
Old Jan 6, 2009 | 11:41 PM
vortech01vert's Avatar
vortech01vert
Default having a problem
ok so when i had my kenne bell on it started acting really weird like it had a miss up top and then one day it started idling very badly like it had a huge cam.i checked the plugs and they were fine,so i took it off and turned it back to stock. well now when i start it it will start but just die. it wasnt smoking, ticking or knocking when it was acting bad so i didnt think it was anything major but now im begining to wonder if it is. whats weird is if i take the air filter off and put my hand over the maf the car will idle but as soon as i remove my hand it will die. anybody have a clue what the hell is wrong?
Old Jan 7, 2009 | 12:42 AM
SVTeeshirt's Avatar
SVTeeshirt
Throwing some ideas out there, did you go with a larger maf when you were f/i? Is it tuned for a larger maf? is the stock maf there? or is it still aftermarket if you did go aftermarket?
Old Jan 7, 2009 | 11:58 AM
vortech01vert
i had a larger maf but i put the stock maf and injectors back on. and i took the chip out so it turned the computer back to stock
Old Jan 7, 2009 | 12:30 PM
SVTeeshirt's Avatar
SVTeeshirt
did it have an aftermarket tune other than the chip? you were running a supercharged engine on an otherwise stock tune? could have been ur KB problem.
Old Jan 7, 2009 | 01:20 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Hows your oil and coolant look?
Old Jan 7, 2009 | 01:31 PM
vortech01vert
it was a chip inserted into the computer that was tuned for the kb, the oil and coolant look fine. i really wanna get it running cause a guy wants to buy it but not until its running.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
