Clutch problem
Old Jun 6, 2005 | 06:37 PM
StangGt01's Avatar
StangGt01
Default Clutch problem
Hi i've just replaced my stock clutch with a new Ford Racing HD clutch the problem is that it's not frictioning. what could be wrong?
Old Jun 6, 2005 | 07:08 PM
JHonor's Avatar
JHonor
Default RE: Clutch problem
No idea, but I've come to find that some of these clutches aren't worth a crap. I replaced mine about 10-15k miles ago with a SPEC stage one. It did ok until recently, but it burns in reverse sometimes, and now it's starting to go into first hard. The throw out bearing has chirped like a bird at idle and low rpm for most of the time its been in there. Not sure what I'm gonna do yet, but I might have to research clutches to find a better one that can handle the rigors of a daily driver (ie: traffic jams, etc.)
Old Jun 6, 2005 | 07:33 PM
StangGt01's Avatar
StangGt01
did you get a firewall adjuster ? Because of the stronger clamping force that the spec has
in my case it is not needed i have something else that I can´t find out
Old Jun 7, 2005 | 01:09 AM
silvergt's Avatar
silvergt
i had a spec stage 2 installed awhile ago and the throwout bearing did the same thing it eventually went away on mine but it really had me worried
Old Jun 7, 2005 | 12:27 PM
JHonor's Avatar
JHonor
Yeah mine chirps most of the time, but it you barely push the clutch pedal and put some load on it, it stops. My shop said they are just like that, it shouldn't give me trouble over the noise. But no, I have no firewall adjuster.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
MasterLanMan
Sep 13, 2015 08:21 PM
Brandonfilipponi@yahoo.com
Sep 12, 2015 11:39 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
