Major running problem
Old Jun 7, 2005 | 09:22 PM
brianftmfl's Avatar
brianftmfl
Default Major running problem
Hi guys i'm kind of new to this site. I have a 1996 mustang GT (the mods list is below.) It had been running good for quite some time. All of a sudden it came up with a b1s1 O2 problem and it would run rough at low RPMs. It also went from 280mi. a tank to less than 175. so I replaced the proper oxygen sensor. I cleared the codes and ran the car for about another thousand miles without any problems and I recovered my fuel mileage. B.T.W. my car has O2 emulators because it has no CATS. After that thousand miles it started acting up again so I pulled the codes and sure enough it was the same codes that pointed to the same O2 sensor. I warrantied it out and it was fine again for about 200 miles and it was back to running like sh*t and eating fuel. Again it came up with low voltage B1S1 and B1S1 too lean. It is even acting like an O2 does on a ford when it goes bad but there is no way that both are defective. Does anyone have any experience with this problem? Also does the O2 rely on a groung reference through the exhaust pipe? Any help would be greatly apreciated. Thanks in advance -BRIAN
Old Jun 8, 2005 | 01:53 AM
silvergt's Avatar
silvergt
Default RE: Major running problem
i put elimanators in mine and it messed up again after a thousand miles or so and i even tried makin sure they were pluged in and they are , hey when its sluggish like that does it kinda sound a little bit like its misssin cause mine does that to
Old Jun 8, 2005 | 01:55 AM
LIVIN_LEGEND's Avatar
LIVIN_LEGEND
could elimanators go bad?
Old Jun 8, 2005 | 02:21 AM
02StanGT's Avatar
02StanGT
ORIGINAL: brianftmfl
I have had this happen to me too. I replaced all the O2 sensors and still had the codes. Then I got my Predator tuner and switched off the back two O2 sensors (the ones with the MILs) and it ran like a charm. So the MILs may have gone bad. Try taking them off and see if that may help.
Old Jun 8, 2005 | 02:56 AM
silvergt's Avatar
silvergt
yea im going to have a sct chip burned in the future and have them turned off
djbigskrilla
Sep 20, 2022 01:04 AM
KinneyD
Jan 9, 2016 05:33 PM
Luclin999
Sep 7, 2015 11:33 PM
jjwinel78
Aug 17, 2015 03:34 PM
Pain.
Aug 7, 2015 10:48 PM
