Need help
I need some engine knowledge. Well I understand that if you have a car making over 500hp then you need stronger internal parts to keep your engine "healthy", but what is everything you need? I read WORDS in another post that you need cams, rods, pistons, forged internals, and short/longblocks???// What exactly is all this stuff and what do they do and why are they important to have? Also i saw this on the MPH site http://modularpowerhouse.com/product...11970cc35f3374 and I was wondering if this is a brand new engine or what? I know its alot but i would appreciate the HELP!! thnx!
basically you need a good built bottom end to hold up
steele crank, h beam rods, forged pistons, and a good set of molly rings. the heads and cams can be stock, the bottom end is what takes the abuse
So as long as im under 500hp then i can leave everything stock or do i need those internal parts? And i love the license plate!! Thinkin of gettin mine personalized but dont know what to put on there???
I went to seanhylanmotorsports.com and found a 4.6l cobra crank, manley h rod, and manley dish pistons!! Will the cobra crank fit my 03 GT? And does it matter if the pistons are flathead or not?/ What are molly rings??
ORIGINAL: StangGT804
as far as the flat top or dished issue it depends on what you are doing, if you want to boost your engine you want a lower compression pistion, and the more you plan to boose the lower your compression needs to be, if your shooting for 500 hp a good 8.5 to i compession is what you want, but if you want to boost her more, i have 17cc dishes in mine its 7.8 to 1 compession, but i also plan to remove the kb in the neer future and replace it with an ati procharger with 20 to 25 psi boost. im looking for 800 plus rwhp. stoack compressin i wouldent recomend any more tahn 9 psi and that should get you close to 400 rwhp.
