Help
need help with misfire on cylinders 1 & 5.new ignition parts new custom motor ,has kenne bell s/c.good spark,fuel press,compression,no vacuum leaks found.did leak down test,only 5% leakage and no codes,injectors were removed and tested no problems found.firing order is correct on coils.fuel trims all over the place on scanner. possible ecu problem?
