11in clutch
Old Feb 13, 2009 | 12:55 AM
nateCR's Avatar
nateCR
Default 11in clutch
hey guys bought a t45 out of a 99 cobra with 13k on her. has a good 11in clutch to replace my tr3650. what is the best and cheapest flywheel so that i can use the 11in clutch? i'd rather use it then buy a new one, unless the flywheel is more expencive then a new clutch kit... is there a stock 4.6 flywheel in some app the can accept the 11in and a 6 bolt fly???
also will my tr3650 clutch fork work with the t45?
thanks
Old Feb 13, 2009 | 03:28 PM
nateCR's Avatar
nateCR
no one>?
Old Feb 13, 2009 | 04:31 PM
lizzyfan's Avatar
lizzyfan
Underboss
Don't think there is one that's inexpensive 11" 6 bolt
Old Feb 13, 2009 | 05:49 PM
joaquinGT's Avatar
joaquinGT
wait if you have a t45 now, you are going to need an 8 bolt. Am I correct? and you should try to resurface that flywheel you have or get a new 10.5´´ clutch kit and flywheel
Old Feb 13, 2009 | 08:39 PM
Bullitt5339's Avatar
Bullitt5339
The Bullitt has an 11" clutch and 6 bolts, i believe.
Old Feb 13, 2009 | 09:24 PM
nateCR's Avatar
nateCR
well came off of a cobra. ie diff bolt counts and bigger clutch. i'll look into the bulliet any one have an idea of year range to look for?
Old Feb 14, 2009 | 09:43 AM
Bullitt5339
They only made the Bullitt in '01
Old Feb 14, 2009 | 09:51 AM
Bullitt5339
I just looked up the part number for the Bullitt flywheel, and it showed the same as the GT, so it may be as simple as just relocating the dowel pins in your existing flywheel for the larger clutch.
I also looked it up, and the clutch for the Bullitt is indeed 11", so if I were you, I'd test fit on the GT flywheel, since they're the same part number as the Bullitt, the dowel pins are easy to relocate, and you may already have what you need.
Old Feb 16, 2009 | 02:55 PM
nateCR's Avatar
nateCR
thnkas for the info man. anyone else tried this?
Old Feb 16, 2009 | 03:06 PM
nateCR's Avatar
nateCR
well i looked it up and the flywheel is a 6 bolt and as long as the bulliet cluch is confirmed at 11in should work right?
