Boost and A/F
My friend gave me his gauge pod with Electric Autometer Boost and A/F gauges. All that I have is the pod and the gauges themselves along with a bunch of wires. My question is What else do I need? In essence, what am I running the wires to in order to get the readings? I'm pretty sure I can figure out the wiring for the power but I'm clueless about the rest of it.
Here is a decent writeup for a boost gauge install. I know yours is electric but this may still help. In the article it uses fuse number 37 to tap into the light source for the gauge. I did this and the gauge light comes on with parking or headlights which is nice.
http://forums.stangnet.com/699928-ho...lete-n00b.html
For the A/F gauge look up the instruction manual on autometer's website it should help with the install.
For the gauge lights use the white/blue wire coming out of the headlight switch so you can dim the gauges with the dash lights. For 12v power use the empty fuse slot for the convertable top. If its a narrow band a/f guage then don't bother installing it. T into the vavuum lines for the boost reference.
Thanks for the replies. But I know there's stuff that I'm missing, I know I must need some kind of sensor for the gauges to wire to. All i have are the gauges and wires. What kind of sensors do I need that will input into the gauge?
