headlight knob help!!!
i am trying to remove the gauge cluster in my 97 gt. in my haynes manual it says use small screwdriver to depress the retaining clip. i have been depressing all day and cant figure it out. can someone tell me how to remove the headlight switch **** please??? thanks.
I took mine off several times before I replaced it. Never had a problem. I used a hooked pick. Just kinda pull up/out on the clip while you pull out on the ****. Never took more than one try, but never tried it with a screwdriver, though...
I just pryed mine very carefully. My **** wore out so I got a dressup one from UPR. It came w/ a tool to remove the stock one(which for me was worn out) and to install the new one. I think it may have been a tiny allen wrench or something.
I just used a thin flat blade screwdriver and not depress it but pulled the light **** out while also trying to pull up on the clip. Real easy, just a couple of seconds, putting on ....well that's a piece of cake.
Seanam
Oct 4, 2015 10:15 AM
