IAC Restrictor...does it work?
As some of you know my IAC is floating...so my idle is way up for rolling and stopped idle...i cleaned it but it didnt do jack, i found this restrictor for 11 bucks shipped, will this work or hsould i just bite the bullet and get a new IAC?
http://cgi.ebay.com/ebaymotors/4-6-M...Q5fAccessories
thanks guys
thanks guys
It will not fix the IAC if that's what you are asking, and would likely make the idle worse...
The restriction mechanically limits the air-flow through a working IAC so as to make the idle drop faster between shifts--there are a number of "dashpot" settings in the tune that can do this as well--and better...
A better way to make this mod is the use a 1/2" copper pipe cap, drill a hole in it (start at 17/64"), and then stick it into the feed tube to the IAC. It does the same thing and is much easier to tinker with than the gasket.
mungodrums
Oct 7, 2015 04:01 AM
M3hunter
Sep 5, 2015 03:42 PM
