Rear-end "wiggle"...
Old Apr 23, 2009 | 05:32 PM
FixFalcon's Avatar
FixFalcon
Default Rear-end "wiggle"...
Whenever I go over the slightest bumps on the road while accelerating, the ***-end of my car wiggles and sloshes very annoyingly. What suspension mods do I need to keep the rear planted while going over bumps? Upper/Lower control arms? Panhard bar? Thanks.
Old Apr 23, 2009 | 06:26 PM
Mustang_NTriangle's Avatar
Mustang_NTriangle
Full length welded subframes and lca's.
Old Apr 23, 2009 | 07:04 PM
Frostbitten's Avatar
Frostbitten
the rubber bushings in your rear end is the cause. They are likely worn out causing excessive movement. You can swap them out for stock stuff or upgrade to urethane bushings.Its the bushings in the upper and possibly also the lower control arms. check the swaybar bushings too.
CS2007
Jun 25, 2019 09:45 PM
CS2007
Florida Regional Chapter
Sep 29, 2015 12:06 PM
Sep 17, 2015 07:57 PM
Sep 10, 2015 08:39 PM
